basic constraint problem
elmehdimabrouk
Message 1 of 13
elmehdimabrouk
hi!
i want part 1 to be in the middle of part 4, knowing that part 1 is already constrained flush with part 4.
if a=90 i can flash it with part 2 or 3 with an off-set but a=73.
Replies (12)
Message 2 of 13
JDMather
Attach your file(s) here.
Message 3 of 13
SharkDesign
What part do you want 1 to be constrained with? Your description is confusing.
Do you always want 1 to be parallel with the ground?
Mate the central axis of 1 and 4 and apply an angle constraint between 1 and the ground.
  Inventor Certified Professional
Message 4 of 13
elmehdimabrouk
here it is
Message 5 of 13
JDMather
@elmehdimabrouk wrote:
here it is
An assembly must include parts.
Message 6 of 13
johnsonshiue
Hi! I suppose you can use Symmetric constraint. But, without see the files, it is impossible to tell. Please zip up the files and attach it here.
Many thanks!
Software Test Engineer
Message 7 of 13
elmehdimabrouk
it includes 2 parts
stru-lmnr cipied one time & stuc-lmnr2 copeid 4 times
Message 8 of 13
elmehdimabrouk
here it is
Message 9 of 13
johnsonshiue
Hi! Please share the ipt files also. Zip them up and attach it.
Many thanks!
Message 10 of 13
elmehdimabrouk
this file contains the parts and assambly
thank you !
Message 11 of 13
elmehdimabrouk
like this ?
Message 12 of 13
johnsonshiue
Hi! This case can be done by Axial-Axial mate. The faces are not parallel. I have re-attached the same assembly files in zip so JD can take a look.
Many thanks!
Message 13 of 13
elmehdimabrouk
yeah axial-axial mate !!
i made it
thank you a lot, all of you
