basic constraint problem
elmehdimabrouk
690 次查看
12 条回复
1 条消息(共 13 条)
elmehdimabrouk
hi!
i want part 1 to be in the middle of part 4, knowing that part 1 is already constrained flush with part 4.
if a=90 i can flash it with part 2 or 3 with an off-set but a=73.
0 个赞
691 次查看
12 条回复
回复 (12)
2 条消息(共 13 条)
JDMather
Attach your file(s) here.
3 条消息(共 13 条)
SharkDesign
What part do you want 1 to be constrained with? Your description is confusing.
Do you always want 1 to be parallel with the ground?
Mate the central axis of 1 and 4 and apply an angle constraint between 1 and the ground.
  Inventor Certified Professional
4 条消息(共 13 条)
elmehdimabrouk
here it is
0 个赞
5 条消息(共 13 条)
JDMather
@elmehdimabrouk wrote:
here it is
An assembly must include parts.
0 个赞
6 条消息(共 13 条)
johnsonshiue
Hi! I suppose you can use Symmetric constraint. But, without see the files, it is impossible to tell. Please zip up the files and attach it here.
Many thanks!
Software Test Engineer
0 个赞
7 条消息(共 13 条)
elmehdimabrouk
it includes 2 parts
stru-lmnr cipied one time & stuc-lmnr2 copeid 4 times
0 个赞
8 条消息(共 13 条)
elmehdimabrouk
here it is
0 个赞
9 条消息(共 13 条)
johnsonshiue
Hi! Please share the ipt files also. Zip them up and attach it.
Many thanks!
0 个赞
10 条消息(共 13 条)
elmehdimabrouk
this file contains the parts and assambly
thank you !
0 个赞
11 条消息(共 13 条)
elmehdimabrouk
like this ?
0 个赞
12 条消息(共 13 条)
johnsonshiue
Hi! This case can be done by Axial-Axial mate. The faces are not parallel. I have re-attached the same assembly files in zip so JD can take a look.
Many thanks!
0 个赞
13 条消息(共 13 条)
elmehdimabrouk
yeah axial-axial mate !!
i made it
thank you a lot, all of you
0 个赞
