Background text on drawings
Message 1 of 11
Hi to all,
Maybe the issue is really simple to solve but I cannot find how to do it.
I have the necessity to write text on the background of a drawing ("company confidential" in the specific case). I have tried to write it on a sketch but I do not know how to place it in backgroun (see png attached).
How do you manage it? Thanks!
Replies (10)
Message 2 of 11
mdavis22569
Make a sketch symbol of it ..
That way you can remove it after the drawing is done...
Are you looking for something like this?
Mike Davis
Message 3 of 11
Thanks for the suggestion, but it does not solve the problem: also in your screenshot I see that the text goes over the drawings, which is not good. The text must not cover the drawings.
Message 4 of 11
mdavis22569
Then do it in the border if you don't want to be able to remove it ....
Mike Davis
Message 5 of 11
mcgyvr
Currently not possible directly in Inventor..
I would suggest printing the drawings to PDF and using their built in watermark functionality/stamps,etc...
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Inserting-watermarks-int...
https://forums.autodesk.com/t5/inventor-forum/transparent-text-watermark/td-p/6733884
Message 6 of 11
mdavis22569
@mcgyvr gives a good option ...watermark it in the PDF
Mike Davis
Message 7 of 11
Thanks for the answer, but still it is not good, as you can see in the attached image still the text goes over the sketch.
At the end I think it is not possible directly in Inventor.
Message 8 of 11
mdavis22569
What's you're looking for isn't possible ...
It's always going too. It'll never void out for where the views are. The views can reset on changes, or shift / be moved.
As @mcgyvr point out ... the AKN about Watermark, or use a sketch symbol like I saw in the beginning.
You could make it smaller and pattern it all over the sheet in a lighter color maybe
Mike Davis
Message 9 of 11
-niels-
I went a bit creative and made the text a transparent png in photoshop, then added the image to a sketched symbol.
Result:
png attached
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 10 of 11
mdavis22569
that's what I was trying to explain ..
Thanks @-niels- for that ....
Mike Davis
Message 11 of 11
Nice! This could open the way to a solution! Thanks a lot!
