automatically have things changed correspondently
180076S7WEQ
180076S7WEQ
I have this click where the 1's are all the same size width and the same length apart but this is a old coworker his drawing and he has no clue where it is and is not working here anymore, anyone have any idea how he has done this.
i was told he was able to change one thing and then have all the ones change, or all the V's change.
Thank you in advance for ur help.
Have a great week!
JDMather
That is all done incorrectly.
Attach your file here for demonstration on how to do correctly.
The corrected version will use:
Dimensions
Blocks
Construction lines/circles.
johnsonshiue
Hi! I think you are talking about the Auto-Scale behavior in 2D Sketch. Go to Tools -> App Options -> Sketch -> check "Auto-scale sketch geometry on initial dimension." As the option indicates, the scaling only happens when you place the very first dimension (there are no other dimensions on the sketch and the geometry isn't constrained to a piece of projected geometry).
Please try it out. It should work.
Many thanks!
Software Test Engineer
