Message 1 of 9
Automated centerlines
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I'm dimensioning circular components & the section view is a bit crowded, I often pull out a larger scale detail view from the section & dimension that. In order to dimension diameters, I use the automated centerline command to generate the centerline then use linear diameter dimensions. With the last few drawings I have done the automated centerline command has not produced any result unless I expand the detail view so that it includes the centre of the circular part. In the past this was not necessary, Inventor was happy to add a centreline outside of the detail view boundary. Is this a deliberate change or is this behaviour wrong?
Inv 2019 pro
