AFTER COMP CRUSHED HAD TO REINSTALL OPERATING SYS WIN64.
I HAVE SUBSCRIPTION ACTIVE FOR THIS PRODUCT
Autodesk Product Design Suite Ultimate 2018
Solved by Mark.Lancaster. Go to Solution.
I HAVE SUBSCRIPTION ACTIVE FOR THIS PRODUCTAutodesk Product Design Suite Ultimate 2018
@Anonymous Your post seems to be lacking a question or problem statement..
Please update your post to ask a question or something.
If you are having problems with language please post in your native language and we can try to translate it.
you don't really say what problem your having
DarrenP
Hi! You should be able to download Autodesk Product Design Suite Ultimate 2018 if you have an active maintenance account. Please log on to Autodesk.com and find the download page.
Many thanks!
@Anonymous
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
That's the only way you are going to get MDT.. Its old, its retired and no longer supported. There's no direct download link for it anymore.
Mark Lancaster
mdt was discontinued
2009 was the last version
way before the design suites were introduced
DarrenP
@Mark.Lancaster provided the link
did you click the link?
DarrenP
@Anonymous
Did you read the article I provided?
That's only how you get MDT so you can convert your files over to Inventor.
Mark Lancaster
Thanks Mark.
Unfortunately I already installed Inventor 2018 without VS2005 x86
Also I do not have IV 2009 to access Inventor 2009.reg.
Your page breaks up on 6. line.....
the link was provided already: https://knowledge.autodesk.com/support/inventor/learn-explore/caas/sfdcarticles/sfdcarticles/Import-...
here it is again
DarrenP
