Autodesk process analysis problem with saving changes
There seems to be a problem with Autodesk Process Analysis, the problem being that lines you make from one operation to another for some reason resets and do not get saved, so if we change a line so that it look good and dosent cross over another operation box and then save, it still reset to default and then cross the other operation box.
screenshots have been attacthed to the post
on the pictures you can see how the lines are out of order and they cross other operation boxes, this was not how we made it, we placed them so they would not cross, and so that if you open a box it would again change the line to look proper and good. even if its a minor problem, it is a fundamental simple thing that need to be in order for my groups project and we dont want to place them everytime we need the process overview it is very tedious work.
if possible it would be nice that this mistake got fixed, so that the program saves all the changes and dont change the lines back to its default state again.
johnsonshiue
Hi! I believe this is related to Factory Design Utility. I have informed the project team about this issue.
Many thanks!
Software Test Engineer
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Factory has its own forum and I will have the moderator relocate your posting there to best suit your needs.
https://forums.autodesk.com/t5/factory-design-utilities-forum/bd-p/510
Mark Lancaster
jzhangustc
Thanks for reporting this issue.  This is a known issue for reconnect command.  The workaround is to delete and recreate the connection lines. Sorry for the inconvenience.
Jun
https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png
