Inventor 2019 student version issue
Samuel.TorresSY2F9
Samuel.TorresSY2F9
My name is samuel Torres and I have a student account using my college email. Normally, I'm able of download and use all the software available to download as student version.
But for some reason, I downloaded Autodesk Invertor (and I logged in using my student version) with no issue, but the software keep saying that is a trial version of just 30 days and will expire after that.
Is there any way to fix this?
Why is just 30 days available for student?
How can I use inventor for more than 30 days as student??
Any help to fix this is more than appreciated.
Kind regards!!
JDMather
STOP!
Q1.  Do you have it running normally in 30-day trial mode?
A1.  If yes, good.  This is what I advise my students to do - run in 30-day trial mode for at least a couple of weeks to make sure all is well.  Each day when then start Inventor it will pop up a message indicating how many days are left in the trial.
In that same message is also a link to Activate the 3-yr student license.  Once they are satisfied that Inventor is installed properly and all functions are working normally (especially Studio, FEA and Dynamic Simulation) THEN AND ONLY THEN do I recommend that they click on the link to Activate their free 3-yr student license.
Can you ask your instructor to join this discussion?  Your instructor should have given you this same information.
johnsonshiue
Hi! You need to first obtain your education license by following the instruction.
https://knowledge.autodesk.com/customer-service/download-install/activate/find-serial-number-product...
Once you have the designated serial number, you can reset your license.
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-change-or-reset-l...
Many thanks!
Software Test Engineer
leowarren34
License with SN will appear in: https://manage.autodesk.com
Should say student in summary.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
