Autodesk Inventor: Render does not include assembly
Message 1 of 9
I am trying to take a simple render capture of a room I made in assembly. I have been changing the shelving style and was able to get great renders of past styles. But for some reason the render does not include my assembly for this file. I am attaching a zip folder with everything inside.
Replies (8)
Message 2 of 9
leowarren34
Next time you upload an assembly please pack and go, I've tried to resolve most of it, I've done a brief render..Finished Room Acrylic.png
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 9
JDMather
@Anonymous wrote:
... does not include my assembly for this file. .
What is the name of this assembly file that is missing.
There are a large number of part files missing from the folder that you attached here.
Message 4 of 9
I apologize for missing parts of the assembly. But I closed and opened a third time, and I guess third times a charm because I ended up with a full render.
Thanks for all the help
Message 5 of 9
JDMather
Are you using Projects (*.ipj) or are you using Vault?
Message 6 of 9
johnsonshiue
Hi! The attached file does not contain Sample Room.iam and its ipt files. Please attach them. Also, share the rendering image showing the problem.
Many thanks!
Software Test Engineer
Message 7 of 9
Unfortunately, I do not know where the issue was, but I will attach the render I ended up with.  I am fairly new with Inventor and I am trying to learn as much as I can through tutorials as i do not have access to a professional training program.
Message 8 of 9
leowarren34
@Anonymous That looks more like it...
The best way to learn is use inventor, I started by picking objects and rebuilding them, using tutorials to learn the skills and eventually you'll cover a wide range of skills.
Neil Cross does excellent videos: https://www.youtube.com/channel/UCF7zEkelSRiHB1rOnspaBgQ
Leo Warren
Message 9 of 9
aaron.tw
Hi @Anonymous -
I edited your post title to make it a little more clear and easier to find for future users 🙂
You already have your answer, but now if other people have the same problem in the future, they can find your question and get the same answer as you!
-Aaron
Aaron Weiss
