Autodesk Inventor Professional 2025.2 Update : Available Today!
dan_szymanski
Autodesk Autodesk
Message 1 of 16
dan_szymanski
On behalf of the Inventor Team, I am pleased to announce the availability of the Autodesk Inventor Professional 2025.2 Update. Please check your Autodesk Account, or Autodesk Access to download and install your update.
Our point release updates include fixes for issues, however also include customer driven enhancements. Be sure to check out the What's New content, the What's New Blog, or the Release Notes for more details regarding what is included within the 2025.2 Update. We hope you find value in the diverse set of productivity improvements this update contains.
Dan
Dan Szymanski
Sr. Product Manager
Replies (15)
Message 2 of 16
Scottyos
Just a question that you might be able to help with. I noticed while reading the 2025.1 release notes there was "access iproperties from the parts list" I'm just curious if I have to do anything special to have that option pop up. When I look at the release notes, that would be very helpful to my workflow however when I'm right clicking the parts list I'm hot having the iproperties option show up. Just curious if I'm missing something here?
Message 3 of 16
Ray_Feiler
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 4 of 16
dan_szymanski
Hello @Scottyos,
The only thing "special" that you need to do is ensure your cursor is placed directly over the row or text within the parts list. Likewise the iProperties access is available when editing the Parts List as well.  More info is available here and here.
Dan
Dan Szymanski
Sr. Product Manager
Message 5 of 16
Scottyos
Thanks for that! The first times I was looking at it, it wasn't there. but when I looked again late yesterday it was there. I was thinking it shouldn't be this tough, but thanks for the response!
Message 6 of 16
s.mayrUPNDP
Hey there,
What's the best solution for making an automatic generated part list?
I want to define the things which should be in the part list before in the part / asssembly properties and then join them all together in the part list. Also for content center files.
Does anyone know a solution??
BR
Simon
Message 7 of 16
SBix26
Please start a new topic!  This has nothing to do with the subject of this topic.
Sam B
Inventor Pro 2025.2 | Windows 11 Home 23H2
autodesk-expert-elite-member-logo-1line-rgb-black.pngautodesk-expert-elite-member-logo-1line-rgb-black.png
Message 8 of 16
NorthernCADMonkey
Just did the 2025.2 update, and now data standards will not start. powershell error referencing $breadcrumb.ps1:84 char.5
Anyone have any ideas on this. Never had data standard errors on otherdot updates.
ANYONE? with not being able to uninstall the 2025.2 update this has really put a dent in our workflow now.
Anyone from the Data Standard group have any ideas?
IVPro 2027 / Vault Pro 2027 / VDS 2027
Windows 11 Pro / RTX 4000 ada / i9 2.2 / 64 RAM
Message 9 of 16
johnsonshiue
Hi Robert,
I am not aware of this issue. Is this Inventor 2025.2 update or Vault 2025.2 update? If Inventor 2025.2 is uninstalled, does Data Standard work?
Many thanks!
Software Test Engineer
Message 10 of 16
NorthernCADMonkey
I should be clear, had Data Standard installed and working on 2025 / 2025.1 and same for vault. Did the Inventor 2025.2 upgrade today and now data standard will not start in inventor, Vault with 2025.2 & Data Standard Seems to be fine. No way to uninstall Inventor 2025.2 that know of is there? I thought  windows has removed the ability to do that. Dont want to do a full Inventor reload if at all possible.
Message 11 of 16
ChrisMitchell01
Please repost this in the Vault forums as you're more likely to get help there. Also, please clarify in your post if you also installed the most recent Vault update or only Inventor 2025.2.
You "can" uninstall these updates but on win11 you need to use the command line, as Microsoft removed the ability to uninstall product updates from Add/Remove programs. For further info around that see https://forums.autodesk.com/t5/installation-licensing/windows-11-doesn-t-show-installed-updates-othe...
The command line (Run as administrator) to uninstall Inventor 2025.2 (build 293) should be :
"C:\Program Files\Autodesk\AdODIS\V1\Installer.exe" -i uninstall --trigger_point system -m "C:\ProgramData\Autodesk\ODIS\metadata\{C275CFC9-BDCC-3330-92D0-452F45E92B6A}\bundleManifest.xml" -x "C:\ProgramData\Autodesk\ODIS\metadata\{C275CFC9-BDCC-3330-92D0-452F45E92B6A}\SetupRes\manifest.xsd"
Hope this helps,
Chris
Chris Mitchell
PDMS Customer Engagment Team
Message 12 of 16
oliver.tilbury
Hi there
I was about to update my Inventor from 2025.1.2 to 2025.2.
I'm having to do this by looking for the update on the online Product Updates page on my account log in as the update for 2025.2 is refusing to show on my Autodesk Access program on my machine and having been checking often over the last few weeks.
However I now see that on the Product Updates page online, it is only the 2025.2.1 update that is now available.
Will this cause any issues if I download this update and update my Inventor from 2025.1.2 straight to 2025.1.2?
Will that miss any updates I should have got with the 2025.2 update?
Many thanks indeed.
Message 13 of 16
johnsonshiue
Hi Oliver,
A few years ago, Inventor updates become all inclusive. This means there is no need to have any prior updates installed. You can install the latest update on top of any build of more recent releases (2025, 2024. and 2023.3?). And you will get all the current update and prior updates.
Many thanks!
Message 14 of 16
oliver.tilbury
Many thanks for the info Johnson.
That's good to know. 👍
Oliver
Message 15 of 16
subashNRBSZ
Community Visitor
Community Visitor
Hi
               i have facing problem Autodesk inventor 2025.2. Continuously inventor close and Hung my systems.
Entire project Stuckel anybody to Help us.
Regards
N.Kadhar Mohideen
Message 16 of 16
johnsonshiue
Hi Kadhar,
Have you installed 2025.2.1 update? Please start a new thread describing the issue in more detail. Does it happen randomly or you can reproduce it persistently? Send me an email ([email protected]). I would like to understand the issue better.
