Autodesk inventor error report
infoGGN9D
infoGGN9D
Community Visitor
Community Visitor
Good morning all,
is about 2 days or more then inventor crash a lot, especially when i try to save file or open a file, no matter if it was a part or idw, i leave a screen whit error report.
Gabriel_Watson
Install all updates, install the latest drivers for your PC components, and ensure the files' full path (file name + all folder names) is shorter than 255 characters. Describe here the steps that cause a crash repeatedly, and if you can, please attach a sample file that causes such crashes.
Also, check the following article for other possible causes and fixes:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Hang-or-crash-when...
johnsonshiue
Hi! Based on the crash report ID, I have tracked down the defects related to the crash (PDM-39713 and INVGEN-69107). The defect has been fixed recently by Vault. The fix will be available in the coming Vault 2023.4.1 update and later Vault 2024.x update.
Many thanks!
Software Test Engineer
