@scottmoyse wrote:
@jdits7 I have to ask this. Why don't you just post links to the Autodesk content on here, instead of the content you copy & paste into your blog posts?
@scottmoyse , I don't know if @jdits7 is doing it "correctly", but I will say that in the past, Jamie was often the first to post detailed information about the Inventor What's New. Often doing so many days before Autodesk published anything.
I've also referred to this page:
http://www.inventortopix.com/p/whats-new-docs.html
more times than I can count, because his information has stayed put so that I could find it years later, long after Autodesk had changed their content location and broken all of the bookmarks that I'd created.
The last few years, Autodesk seems to be getting the information out sooner, but I still appreciate that Jamie has done it "his way", right or wrong, when I need to look up to see what release a new feature came out!
In any case, I thank http://www.inventortopix.com and https://designandmotion.net/ for the efforts.
Also, just to tie the information together for future reference here are some related Autodesk Inventor 2016 What's New links:
http://help.autodesk.com/view/INVNTOR/2016/ENU/?contextId=HIDWhatsNew
/autodesk/attachments/autodesk/78/541522/1/Inventor%20Whats%20New%202016.pdf
I hope this helps.
Curtis
