Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
AUtodesk error result 1603
Hi
I recently bought a new dell xps 15 2015. I am trying to install inventor 2015 student version however it is not working that is during installation all the features fail to install. I tried installing AIDA and this is what is happening,
I tried looking at other forums having similar errors but none of them worked
I would appreciate the help very much
Thanks in advance
Mark.Lancaster
@Anonymous
Welcome to the community...
Without your installation log file we can only speculate what the issue is.  Either post your installation log file or I will assume its failing due to the method your using.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
The issue with AIDA is most likely related to having numerous files in your personal temp (%temp%) folder.  May be time to clean it out..   Smiley Wink
Mark Lancaster
