- How reliant is your process on publishing DWF files from Inventor and using Autodesk Design Review as a viewing solution? What part is Vault playing in this process?
A few of us at my company occasionally use DWF for reviewing/markup purposes. It's not even an official part of our processes - just something we sometimes choose to do instead of hardcopy markups, which are still the norm here. We largely do this with DWF because we like the Design Review markup tools a little better than BlueBeam. We don't use DWF for general viewing purposes at all.
- Is PDF publishing (2D and or 3D) part of your current or future practice?
2D PDF is the standard way we view drawings. We don't use 3D PDF at all, other than occasionally viewing one sent to us by a customer.
- Do any of you use Inventor View to view Inventor native file formats without publishing? What limitations are you experiencing?
We don't currently use it, although I have suggested it a few times as a way to let our fabrication shop staff view 3D models. It just hasn't gone anywhere yet. Having used it a bit in the past, I agree with all the limitations listed by others in this thread: inability to measure, turn off visibility, switch representations (especially View Reps), etc.
- How do your needs vary when sharing designs with internal partners than external?
What we share externally is typically much simpler. Since we have our own fab shop, most of what we share is just DXF's for cutting plate or sheet metal parts that we can't do ourselves. When we do use an outside shop, we mostly just provide PDF's (along with the DXF cutting patterns, if applicable). Many of the shops we deal with aren't up to speed on 3D, so we have no need to share models with them. One that we work with fairly regularly uses Inventor, so we have sometimes sent them the native Inventor models (via Pack & Go). Sometimes this has been problematic because we are on different upgrade cycles, and so sometimes we have had to resort to sending them STEP files because we had Inventor files they couldn't open.
- Are the viewing tools themselves meeting your needs?
Not really applicable in our case.
- How do you feel about a cloud-centric viewing solution?
Cloud doesn't really hold a lot of appeal to us. All of our branches have access to our company's network (though at varying degrees of performance). So in a way, we are already doing that on our own, without the need to put our data in someone else's hands. The only possible advantage I see to cloud for us would be access to files by personnel operating remotely on jobsites. For the most part they already do this via VPN, or just copy the files locally to their laptop before they leave the office. If a cloud solution could be faster than our VPN, there might be some limited benefits there over what we currently do.
- How do you archive legacy designs? Is a published format (dwf, pdf) part of that archival process?
PDF essentially is our archive process. We preserve PDF versions of all obsolete revisions. In cases of a major change, we will sometimes also archive a copy of the 3D model (Inventor or AutoCAD). We don't use Vault or any other CDMS currently, so this is just done manually in a folder on our network drive. In Inventor's case, we achieve it by using Pack & Go to create a copy, then zipping the folder to prevent Inventor from seeing duplicate file names (as the archive does typically exist within the project's Workspace).
