Inventor Forum
Autocad Architectural in Inventor
4 REPLIES 4
johan.degreef
645 Views, 4 Replies
When I ce-reate something in Architectural, it won't get shaded in invnetor. is this possible?
Inventor 20250, Vault Professional 2025, Autocad Plant 3D 2024
4 REPLIES 4
pendean
in reply to: johan.degreef
@johan.degreef
Ask in the INVENTOR forum, and post your actual DWG file instead of a picture. Here is the link https://forums.autodesk.com/t5/inventor/ct-p/70
Hi Johan,
Please try something for me real quick. Open the dwg file in Architecture and use List command to check the entity type. Is it 3D solid body or wire or mesh? It can only be shaded if it is a solid body or a surface body in Inventor.
Many thanks!
Software Test Engineer
wnisbett1
I have the same question.
I want to use buildings from AutoCAD Architecture in Inventor factory.
All I can get on the open in inventor tab in architecture are the bounding boxes.
If this is the case the open in inventor command from the factory tab in architecture is really useless
JDMather
in reply to: wnisbett1
@wnisbett1
Attach example *.dwg file here for testing.
