AutoCAD 2021 Layer Colors Converted From Index Color To True Color When Drawing Is Opened In Inventor 2021
Steve-CL
Message 1 of 20
Steve-CL
Currently, our company drawing workflow is to create drawings in Inventor and then use Inventor and AutoCAD to finish the drawings. We recently migrated to Inventor 2021 and AutoCAD 2021. We are having an issue with AutoCAD 2021 layer colors being converted from index color to true color when drawing is opened in Inventor 2021. This did not happen with previous versions of Inventor or AutoCAD. I'm thinking it's either a bug in software or a setting that needs to be adjusted.
Thank you,
Replies (19)
Message 2 of 20
johnsonshiue
Hi! The behavior does not sound right to me. I was aware of an issue the other way around (Inventor idw/dwg exported to AutoCAD with incorrect color index). Please share an example that exhibits the behavior here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Message 3 of 20
Steve-CL
John,
See attached.
Message 4 of 20
johnsonshiue
Hi! I see the issue now. Inventor does support AutoCAD Index Color in drawing environment. You can map it to AIC via Export to AutoCAD workflow.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-...
Many thanks!
Message 5 of 20
Steve-CL
Yes, but I do not want to export to AutoCAD from Inventor. This wasn't an issue with 2020.
Message 6 of 20
johnsonshiue
Hi Steve,
This is surprising. I was not aware that the issue did not exist on 2020. Something is wrong. I need to check with the project team.
Many thanks!
Message 7 of 20
liang_chen
Hi Steve,
From the video, there is an inconsistent behavior in AutoCAD when read dwg file if it is opened in Inventor or not. I test this case, I meet the same issue in  AutoCAD 2020.
Do you mind to share a testing file, which works well in 2020, but fails in 2021 ?
Fred
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
Message 8 of 20
Steve-CL
Fred,
I attached test drawing. This is same drawing in the video I will post below.
Steve
Message 9 of 20
Steve-CL
Fred,
This video demonstrates that Inventor 2020 does not convert AutoCAD 2020 index colors to true colors when going back and fourth from Inventor 2020 to AutoCAD 2020 or vice versa. We also had no issues with prior versions of Inventor and AutoCAD e.g. 2019 versions.
Message 10 of 20
Steve-CL
Johnson,
Please review my new replies to Fred.
Steve
Message 11 of 20
liang_chen
Hi Steve,
Thanks for sharing the dataset.
It is reproducible now, and I have reported it as internal ticket and sent it to Development team.
Fred
Fred Chen
SQA Engineer
Autodesk, Inc.
Message 12 of 20
Steve-CL
Is there any new information on this?
Thank you,
Steve
Message 13 of 20
liang_chen
Hi Steve,
Ticket has been created for investigation, and Dev is working on it.
Any update will be updated in this post (INVGEN-51227).
Fred
Fred Chen
SQA Engineer
Autodesk, Inc.
Message 14 of 20
Steve-CL
Hi guys. Do you have any updates on this issue?
Thank you,
Steve
Message 15 of 20
johnsonshiue
Hi Steve,
I just checked the status for INVGEN-51227. There isn't any meaning for update yet. It is still being investigated and there is no fix unfortunately at the moment.
Many thanks!
Message 16 of 20
emiller
We have a customer that is battling this same issue.  Has there been an update to the ticket yet?
Eric
Message 17 of 20
johnsonshiue
Hi! I just checked the defect status. There isn't much progress to report. The latest discussion seems to indicate the issue happened in a shared component used by multiple Autodesk products. Some further investigation is needed.
Many thanks!
Message 18 of 20
Steve-CL
Thanks for update.
Message 19 of 20
jstdrwit
Community Visitor
Community Visitor
Reading thru this conversation I'm running into the same problem using Inventor 2022 & AutoCAD 2022. Has their been any resolution to this issue?  The Exporting idea works but not for templates in Inventor and it's very cumbersome to do when I have to bring drawings into AutoCAD for plotting at multiple design stages of review 10%, 60%, 100%, Issue for Construction, and As-Built w/ field comments.  That's a lot of exporting!  Any info would be helpful.
Message 20 of 20
johnsonshiue
Hi! I just checked the status for  INVGEN-51227. It shows it has been fixed on 2023 product line.
Many thanks!
