The content center has no ASTM spec high strength structural bolts. As far as i know these are fairly common in industry and so I am wondering why they aren't in the content center, and if anyone has created an adjustable one I can get. This is for stress analysis on shearing bolts and as such i need a really precise model. Please let me know
Inventor 2011 Pro
ASTM A325 High Strenght Structural Bolt : 1" D x 39/64" H x 1-5/8" F x 3.5433" long.
Solved by blandb. Go to Solution.
Solved by Frederick_Law. Go to Solution.
Solved by rregaladoUSLWT. Go to Solution.
Copy to custom and rename.
Edit table and rename. Change material if you need. Add missing size. Delete size you don't use.
I just need the name in BOM.
As @Frederick_Law had mentioned. We used F436 FW, A325, ANCO Lock nuts, but none of them were in the CC. So we just used a family that was close and modified to suite what we needed such as descriptions, finishes, etc.
The post is old, but my forum heroes finally provide some answers! Thanks everyone! I'll mark some soluitons so others can find this.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
