Inventor Forum
Assy File face to dxf
14 REPLIES 14
Message 1 of 15
lkirit2000
1071 Views, 14 Replies
Hi
How to create an inventor assy file surface to dxf file for laser cutting.
I am using Inventor 2020.
Rgds
14 REPLIES 14
Message 2 of 15
Xun.Zhang
in reply to: lkirit2000
Hello @lkirit2000,
Create a new part, derived the assembly in and select the face, export surface to dxf from the context menu.
Hope it helps!
Xun
Message 3 of 15
lkirit2000
in reply to: Xun.Zhang
Hi
I am still haven't solve the problem.
Please let me know how to make a derive part?
Rgds
Message 4 of 15
lkirit2000
Hi Xun,
Please see the attached image below, when select all faces, I couldn't get any option " Export Face As ".
Is there any other way to do this ?
Rgds
Message 5 of 15
lkirit2000
Hi
I have attached image.
Rgds
Message 6 of 15
Xun.Zhang
Hello @lkirit2000,
Create a new part, find the command Derive (3D Model\Create) and invoke it, select the assembly and complete the derive workflow. Now you have a part with all geometries from that assembly. Then, select a face, right click the mouse to bring up context menu, select Export face as...
Hope it helps!
Xun
Message 7 of 15
lkirit2000
Hi Xun,
Thanks for your prompt response.
I my derived part has grrove, so I could not select all file in one right click.
When I select the multiple clicks with Ctrl, then right click the " Export Face As " option is not available ?
Rgds
Message 8 of 15
Xun.Zhang
Hello @lkirit2000,
Only 1 piece of planar face is supported.
Please use Unwrap command to make bunch of faces into a single planar face.
Hope it helps!
Xun
Message 9 of 15
S_May
Message 10 of 15
Xun.Zhang
in reply to: S_May
Hello @S_May,
This is really cool! 👏
Xun
Message 11 of 15
S_May
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
End If
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
Try
'Set the DXF target file name
Try
CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR")
Catch
CustomName ="XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert
End Try
oDataMedium.FileName = oFolder & "\" & CustomName  & " " & oFileName & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
End If
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
'just for check its works coretcly
'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
'MessageBox.Show(i,"title",MessageBoxButtons.OK)
'If i=2 Then
'Exit Sub
'End If
oCompDef.FlatPattern.ExitEdit
Catch
End Try
oDrawDoc.Close
Else
End If
Next
Message 12 of 15
Xun.Zhang
in reply to: S_May
Hello @S_May,
How about Non-sheetmetal parts? Any more thoughts? 🙄
Xun
Message 13 of 15
S_May
Hi @Xun.Zhang , @lkirit2000
This solution is only for sheet metal parts, not for normal components and not for flattening in 2020.... Man Embarassed
Message 14 of 15
thenottakenname
in reply to: S_May
Would making a drawing and placing the view of the surface to be cut, then going to save as -> save copy as -> and changing the file type to dxf work? That's how I transport model views to AutoCAD.
Aaron Wilson
Inventor Professional 2022
AutoCAD 2020
Message 15 of 15
S_May
in reply to: thenottakenname
@thenottakenname
  1. You must create all components as sheet metal
  2. for the flat sheet you need no drawing
