Hi
How to create an inventor assy file surface to dxf file for laser cutting.
I am using Inventor 2020.
Rgds
Solved by Xun.Zhang. Go to Solution.
Hello @lkirit2000,
Create a new part, derived the assembly in and select the face, export surface to dxf from the context menu.
Hope it helps!
Hi
I am still haven't solve the problem.
Please let me know how to make a derive part?
Rgds
Hi Xun,
Please see the attached image below, when select all faces, I couldn't get any option " Export Face As ".
Is there any other way to do this ?
Rgds
Hello @lkirit2000,
Create a new part, find the command Derive (3D Model\Create) and invoke it, select the assembly and complete the derive workflow. Now you have a part with all geometries from that assembly. Then, select a face, right click the mouse to bring up context menu, select Export face as...
Hope it helps!
Hi Xun,
Thanks for your prompt response.
I my derived part has grrove, so I could not select all file in one right click.
When I select the multiple clicks with Ctrl, then right click the " Export Face As " option is not available ?
Rgds
Hello @lkirit2000,
Only 1 piece of planar face is supported.
Please use Unwrap command to make bunch of faces into a single planar face.
Hope it helps!
'define the active document as an assembly file Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4) 'check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If 'get user input RUsure = MessageBox.Show ( _ "This will create a DXF file for all of the asembly components that are sheet metal." _ & vbLf & "This rule expects that the part file is saved." _ & vbLf & " " _ & vbLf & "Are you sure you want to create DXF for all of the assembly components?" _ & vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo) If RUsure = vbNo Then Return Else End If oPath = ThisDoc.Path oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap 'get DXF target folder path oFolder = oPath & "\" & oAsmName & " DXF Files" 'Check for the DXF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - - '- - - - - - - - - - - - -Component - - - - - - - - - - - - 'look at the files referenced by the assembly Dim oRefDocs As DocumentsEnumerator oRefDocs = oAsmDoc.AllReferencedDocuments Dim oRefDoc As Document 'work the the drawing files for the referenced models 'this expects that the model has been saved For Each oRefDoc In oRefDocs iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt" 'check that model is saved If(System.IO.File.Exists(iptPathName)) Then Dim oDrawDoc As PartDocument oDrawDoc = ThisApplication.Documents.Open(iptPathName, True) oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName)) Try 'Set the DXF target file name Try CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR") Catch CustomName ="XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert End Try oDataMedium.FileName = oFolder & "\" & CustomName & " " & oFileName & ".dxf" Dim oCompDef As SheetMetalComponentDefinition oCompDef = oDrawDoc.ComponentDefinition If oCompDef.HasFlatPattern = False Then oCompDef.Unfold Else oCompDef.FlatPattern.Edit End If Dim sOut As String sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE" oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName) 'just for check its works coretcly 'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel) 'MessageBox.Show(i,"title",MessageBoxButtons.OK) 'If i=2 Then 'Exit Sub 'End If oCompDef.FlatPattern.ExitEdit Catch End Try oDrawDoc.Close Else End If Next
Hi @Xun.Zhang , @lkirit2000
Would making a drawing and placing the view of the surface to be cut, then going to save as -> save copy as -> and changing the file type to dxf work? That's how I transport model views to AutoCAD.
