Inventor Forum
Assembly
4 REPLIES 4
Scary99
370 Views, 4 Replies
Assembly
I am a student in Inventor.  I have just began using the Assemble Command and experienced no problems. I have tried to assemble a simple piece
(only 2 parts) and cannot get them to mate. I get the same error message "The Assembly Cannot Be Solved" but I do not have the expertise to interpret the error message.  I have tried using axis, work planes and surfaces to constrain and mate the parts but I get the same error message.  I know this is a simple problem but I would like to learn how to interpret error messages and figure out what I am doing wrong on this part to avoid the same mistake in the future. Thanks for your help
4 REPLIES 4
mdavis22569
in reply to: Scary99
unground the 2nd one ...or it'll never move
Mike Davis
JDMather
First thing I would do is Delete any conflicting constraints (Relationships). (! in yellow triangle)
I had a little fun with your assembly (see attached).
Can you figure out what I did?
mdavis22569
in reply to: mdavis22569
also delete the new work plane you don't need it...
Mike Davis
mdavis22569
You have some other issues to fix
My assembly constrained is attached
Mike Davis
