I am a student in Inventor. I have just began using the Assemble Command and experienced no problems. I have tried to assemble a simple piece
(only 2 parts) and cannot get them to mate. I get the same error message "The Assembly Cannot Be Solved" but I do not have the expertise to interpret the error message. I have tried using axis, work planes and surfaces to constrain and mate the parts but I get the same error message. I know this is a simple problem but I would like to learn how to interpret error messages and figure out what I am doing wrong on this part to avoid the same mistake in the future. Thanks for your help
Solved by mdavis22569. Go to Solution.
Solved by JDMather. Go to Solution.
unground the 2nd one ...or it'll never move
First thing I would do is Delete any conflicting constraints (Relationships). (! in yellow triangle)
I had a little fun with your assembly (see attached).
Can you figure out what I did?
also delete the new work plane you don't need it...
You have some other issues to fix
My assembly constrained is attached
