Assembly torus/ hollow cylinder
Message 1 of 16
I am trying to use tangent constraint to make I'd and od of ring to intersect tapered walls. The tapered walls are cutout arc-slots.
Replies (15)
Message 2 of 16
Mark.Lancaster
@Anonymous
Welcome to the community..
You may fully understand what you are trying to accomplish but it doesn't convey in your description..  Provide an example, attach your effort (so far) and always tell us what version of Inventor you are using.
Mark Lancaster
Message 3 of 16
JDMather
Is this a Tangent assembly constraint
or
is this a Tangent sketch constraint?
Attach your assembly here and end all doubt.
Message 4 of 16
blair
If a Torus is involved, there is no single Tangency for Inventor to deal with and produce a solution for mating. A Cylinder has a single tangency which Inventor can solve.
You are going to need to add Work Planes, Work Axis and possibly Grounded Work Points on the Torus to use for mating.
Delta Tau Chi ΔΤΧ
Message 5 of 16
Ok, I will post assembly when I get home from class.
Sent from my Verizon, Samsung Galaxy smartphone
Message 6 of 16
Inventor 2016. See where I am trying to get the OD and the ID mated to the tapered walls of the arc slots.
Message 7 of 16
Inventor 2016
Message 8 of 16
inventor 2016
Message 9 of 16
I did widen my arc notches by.125 per Ø in the sketches on each arm.
Message 10 of 16
blair
The IAM file only contains a data-base of the file names used, their position within the IAM as well as the constraints. It doesn't contain any of the required IPT files.
Please upload all the ITP files that are used in the IAM file.
Delta Tau Chi ΔΤΧ
Message 11 of 16
Still have a few more to upload
Message 12 of 16
Let me know if I missed anything.  I ended up trying a mate instead of a tangential assembly.  It looks right but I could be off.
Message 13 of 16
blair
I guess the easiest is to use the Contact Set and manually bring the ring down to the notched rib until contact is made and Inventor limits the movement. Then measure the distance from the bottom of the ring and the bottom of the notched rib. Use a Flush constraint with the distance for the offset.
JD may have a more refined method.
Delta Tau Chi ΔΤΧ
Message 14 of 16
WHolzwarth
Some of the part files were 2017, therefore an update to 2017 was needed.
Many undefined sketches were found, but most of them left.
Only IAM and Rack were updated and are added, other files can be used again.
Walter
Walter Holzwarth
Message 15 of 16
So how do I use this feature? Is it under the movement tab in Assemble?  I am a novice at Inventor especially when it comes to assembly.  I have more experience using Solidworks and SolidEDGE.
Message 16 of 16
Thanks everyone for your input thus far.  I'm still trying to work it out but I appreciate you taking the time to help solve a question.
