In partlist of a *.idw file, how to display the parts under the subassembly
Solved by lis_wang. Go to Solution.
Solved by cbenner. Go to Solution.
First, in your assembly BOM select Structured and set View Properties to All Levels:
Then in your .idw parts list, (after proper sorting) expand the "plus" signs (+) to show components of the sub-assemblies.
In my image you see a minus (-) sign since the level has already been expanded. Selecting the minus would close that sub-assembly back up.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
