Inventor Forum
pattern feature
3 REPLIES 3
327 Views, 3 Replies
pattern feature
pattern feature should line up correctly at 89.88deg (mirror features lines up at 89.88deg correctly - not used in model but just for this example have included) but picture shows it overshoots slightly.Have i missed something here?
3 REPLIES 3
If you dig a little deeper I think you will find that the 49.44 deg. angle from the vertical centerline to the outside edge of  extrusion is actually 49.43900631.
JDMather
In your Circular Pattern1 dialog box enter 98.87812620444039-9 as the angle.
Or better yet - let Inventor solve the math
Add a reference dimension to Sketch1 (even though Inventor is only showing 2 decimal places in this image - it it keeping track out as many decimal places as it uses internally)
Now simply select the reference dimension in the Circular Pattern dialog box.
In this image I typed in the 9°, but I should have picked the original parameter dimension for that as well.
Any changes should update.
Well, it bothered me too much - I had to go back and fix it properly -
thanking you.i have fixed up
