Assembly Pattern to follow Part Feature Pattern
Hytech-Pommec
Hytech-Pommec
Part: Wondering if it is possible to see wich Feature is the fist once placed, then set in a Feature Pattern
Assembly:  Pattern, then follow the Part Feature Pattern
f.e.
Part:  flat bar , 3 holes..first hole placed in centre, then feature Pattern to the left and right
Assembly:  Place First bolt in?...I am not able to see which hole in Part is placed first..so if i place bolt in right hole and the use the Pattern Command, using the "white"arrow..it is not recognized..it seems i need to place the first Bolt in the centre..
Hopefuly somebody can give me some support
Regards, Paul van Gent
Posted a screen shot below
In your assembly switch to "Modeling" from "Assembly", the part features will then show up, also you can directly click on the part pattern you want to use in your assembly
JDMather
Attach your assembly here if you can't figure it out.
Hytech-Pommec
Mario, briljant ..thanks !!
