- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Part: Wondering if it is possible to see wich Feature is the fist once placed, then set in a Feature Pattern
Assembly: Pattern, then follow the Part Feature Pattern
f.e.
Part: flat bar , 3 holes..first hole placed in centre, then feature Pattern to the left and right
Assembly: Place First bolt in?...I am not able to see which hole in Part is placed first..so if i place bolt in right hole and the use the Pattern Command, using the "white"arrow..it is not recognized..it seems i need to place the first Bolt in the centre..
Hopefuly somebody can give me some support
Regards, Paul van Gent
