Assembly Model Stuck in Orbit mode
Message 1 of 18
Arrow with small cubeArrow with small cube
I have opened a Inventor Assembly created several years ago and migrated the files. However it is stuck in a Orbit mode. It also has a Arrow pointer with a small cube. see attached. any suggestions?
Replies (17)
Message 2 of 18
Wow.
The "small cube" looks more like a "mouse" graphic from years gone by.
When you say "Stuck in orbit mode", you mean it's spinning, or that's all you can do with it?
In the theme of every IT support call response, have you rebooted?...LOL...no, I mean, have you tried the ESC button?
I take it you are unable to select any other commands?
Just in case, be sure to check that nothing in leaning on or pushing on your F4 key or your space mouse.
Speaking of the Space Mouse, unplug it if you have one. Mine gets "stuck" now and then and it'll do the same type of deal, usually I'll see it zooming or rotating at a very slow speed. Oh and blow out your keyboard, I've seen keys stick and do the same thing.
Other than that, does this happen on any other workstation?
Can you post the file?
Message 3 of 18
blair
I would check for either a stuck Function key on the keyboard or mouse button. Then do a system reboot and as well as go to the website of the mouse manufacture and download the latest driver package and re-install.
It doesn't sound like you have a 3D motion controller. If you do, do a reset/recalibration of the device as well, or check that it's not stuck.
Delta Tau Chi ΔΤΧ
Message 4 of 18
I have Rebooted. Switched keyboards, updated drivers. unplugged the 3D mouse but continue to have the same problem. I have uploaded the file onto another workstation and the file works fine.
Message 5 of 18
If it's working fine on another machine, that's telling me it's your machine with the issue. (my Capt. Obvious impression)
If you've done all that and it's still doing this....I'll have to think hard on what it could possibly be.
Give me a few, yet another management meeting to attend...
Message 6 of 18
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous that icon is when you hover over the Viewcube, I have not noticed that behavior before, if you can record a screencast to show how that behaves that would be helfpul.
You could try the Reset Utility or Repair Install.
Just a thought, are you up to the latest Inventor Updates?
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 7 of 18
leowarren34
Are you sure you've got no stuck keys or macros that could trigger this, I had it once, really annoying as I knew it was my computer but what part 🙂
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 8 of 18
johnsonshiue
Hi! You may also need to disable 3D Connexion Add-In.  Go to Tools -> Add-in -> unload 3D Connexion.
Many thanks!
Software Test Engineer
Message 9 of 18
blair
Try unplugging the 3dConnexion device. See if it's an issue with the device.
Delta Tau Chi ΔΤΧ
Message 10 of 18
Done the updates to all the inventor programs. keyboard, mouse, 3D Connexion Mouse. Here is a Screencast.
What is puzzling is it does not do this with all files. Some work fine.
Message 11 of 18
kelly.young
Autodesk Support
Autodesk Support
@Anonymous thanks for sharing the screencast. I don't see your Viewcube in the upper right corner, can you turn it on? Does the behavior react any different?
Message 12 of 18
It will not let me turn the view cube on when it reacting this way.
Message 13 of 18
kelly.young
Autodesk Support
Autodesk Support
@Anonymous maybe reset the Ribbon? Not sure what else you can change as far as a setting goes to make that happen. If you can't turn the Viewcube on at all there is definitely something odd.
If none of the previous things work, all I can think of is a fresh install and that might get rid of it.
Message 14 of 18
Yes, the Fresh Install is probably the only option left. Thanks all for your ideas and suggestions on this puzzling situation.
Message 15 of 18
Well, I think I solved it....at the end of his screen cast one can see he's an Oregon Ducks fan.....j/k.
I have to agree, with everything you've done already and no resolution as well as the View Cube issue, I'd first try a Repair Install or just go right to a fresh install. But before you do that I'd highly recommend getting CCleaner if you don't already and perform your uninstall thru that app. It tends to remove more if not all fragments of the original install. I've had numerous times in the past where I had to do a reinstall and MS uninstall didn't remove everything and it errored out when I attempted to reinstall. Haven't had that issue since being told to use CCleaner...I swear by it.
Message 16 of 18
TheCADWhisperer
@Anonymouswrote:
... I have uploaded the file onto another workstation and the file works fine.
That would seem to isolate it to the machine being the issue, but before doing an uninstall/reinstall can you run this test -
The file was created in Inventor 8, the flat pattern solver was changed after that.
Try deleting the Flat Pattern on a machine where the file will open correctly and recreate the Flat Pattern.
Save the file and then go back and try again on the machine where it will not open.
Message 17 of 18
Curtis_Waguespack
Hi @Anonymous,
I didn't read all the other replies, but did see that the Reset Utility was suggested. This issue seems very similar to the ones reported at these links, which were solved by the Reset Utility. I'm not sure that this will indeed resolve this for you but if you haven't tried it, it would be something to rule out at the least.
https://forums.autodesk.com/t5/inventor-forum/view-cube-problems-after-stp-file-import-inventor-2017...
https://forums.autodesk.com/t5/inventor-forum/can-t-select-plane-to-sketch-on-for-new-part-created-u...
I hope this helps.
Curtis
Message 18 of 18
I tried all the other suggestions short of the total reload of program which was next. The Reset Utility seems to have corrected the problem. Thanks for all the suggestions. I have learned some new troubleshooting along the way. I suspect the older files even though migrated helped trigger the issue coming to the forefront.
