I need to be able to collapse item 1 in the drawing BOM, but still show the bolt material in the material column. Is there a way to do this? See image below...
Assemblies don't really have a material of their own, so I'm not sure this is going to be possible any way other than a manual entry in the parts list.
Even in your simple example, you have two materials. How would Inventor know which one you wanted to be the "assembly material"?
Hi!
Just a workaround... when sending to customers... it's kind of silly, but... it works.
Create a Custom Property in Assembly called MATERIAL (or other) and fill the Material you want.
Then import that Property to the BOM in a new Column and hide the real Material part's Column.
Hi!
@CCarreiras wrote:
Hi!
Create a Custom Property in Assembly called MATERIAL (or other) and fill the Material you want.Then import that Property to the BOM in a new Column and hide the real Material part's Column.
A slight improvement on this method would be to keep the real Material column in the parts list, but add a Substitution to that column to use the custom property instead when it exists. That way all the materials for the parts would show up as they currently do, but the assembly would substitute the "AssyMaterial" property (or whatever you want to name it) if it is present.
@CCarreiras wrote:
Hi!
Even changing it to a weldment doesn't work because it's still just picking the material from a dropdown and not deriving it from a specific .ipt in the assembly.
