Assembly cross-section
不适用
509 次查看
3 条回复
1 条消息(共 4 条)
不适用
When trying to view in cross-section I get the section view but it creates a gray-textured plane that blocks the view. Please see attached jpg.
Did not see anything similar here.
This does not happen usually- only on this assembly, as far as I see.
0 个赞
510 次查看
3 条回复
回复 (3)
2 条消息(共 4 条)
johnsonshiue
Hi! This is a known issue. The behavior started in 2017. It has been resolved in the coming 2017.4. If you are a subscriber, please install it when available. Let me know if it works for you.
Many thanks!
Software Test Engineer
0 个赞
3 条消息(共 4 条)
不适用
Hmmm...
After installing 2018 and getting the same results I saved as step file, reloaded and section went ok.
Only problem, for this purpose, which is producing pictures for patent application, is losing the constraints. Any option to save them?
0 个赞
4 条消息(共 4 条)
johnsonshiue
Hi! I could be wrong but the issue you are encountering does not sound like the known section view problem. Could you send me the example ([email protected])?
Many thanks!
0 个赞
