- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
See attached assembly file... The first two blocks is my first attempt (Called BlackA1)
The next two blocks (Called BlockA2), I put a bolt in them and used the Joint slider command and named the current value "Current".... This is the value I'm searching for... This "Current" Value I want to drive the spacing of the pattern shown... While also allowing me to drag the blocks back and forth.... But as you can see, the pattern doesn't update automatically....I have to edit edit the pattern or use Manage>"Rebuild All" to force it to update.....
So my question is... Is there a better way to do this? The general constraints don't seem to support this. And Joint command was a pain to get to this point... So I feel like I'm missing something...
PS: The goal is to show everything spreading apart as you drag things... the reason is b/c I want to show how things are moving without collisions etc. Also individually placing constraints on everything would be a massive headache as there's something like 300-600 parts I'm going to drive with this pattern.
Inventor: Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
