I'm asking for help.
How to copy a cabinet into an assembly and place one next to each other and resize only on the other.
Thank you .
Solved by johnsonshiue. Go to Solution.
Solved by WHolzwarth. Go to Solution.
A second sub-assembly is needed. Try this:
- Place another component of the board in the main IAM
- Select new component, and in Productivity panel, use Save and Replace and save it with new name
- Edit the new sub-assy, replacing edited parts the same way with new names
Walter Holzwarth
Hi! You need to make the two separate components, not instances of the same ipt/iam file. When you use Copy Component command, make sure you use Create New option. After that, you can do whatever you want with the copied one.
Many thanks!
