ASME B16.5-2020 flat face pipe flanges within Inventor 2024 content center?
CamPhoenix
CamPhoenix
Is there an option to select flat face flange under ASME B16.5 wrought iron pipe flanges within content center already preconfigured? Or does one need/have to duplicate the existing standard library and edit the raised face flange dimensions off?
A.Acheson
Hi @CamPhoenix
I suspect like previous releases you will need to modify yourself either by adjusting the RF thickness to a small value like 0.0001mm or placing as custom delete the face, reauthor and republish.
Regards
Alan
