Creating Parts on a Layer
ethanwTRU9M
ethanwTRU9M
Community Visitor
Community Visitor
Is there a way to create a "part" on a certain layer? So that when the view is brought into a drawing it is already on the desired layer and you don't have to select all the edges and change them with each view. I've seen ways of possibly doing it with code but i was hoping there might be a simpler way. Thanks in advance.
johnsonshiue
Hi! There is indeed a workflow allowing you to export Inventor drawing to AutoCAD Mechanical drawing by assigning Layer Groups. On exporting to AutoCAD dwg, select AutoCAD Mechanical as the file type. You will see the following dialog. Is this what you are looking for?
Many thanks!
Software Test Engineer
SBix26
Nope.  But there is an easier way to change layers on the drawing- find the part in the browser, right click > Select as Edges, then change layers.  That saves the tedium of manually selecting everything.
Sam B
Inventor Pro 2024.2 | Windows 11 Home 22H2
