array part along a Heilix
dwendlandKWUPQ
Message 1 of 14
dwendlandKWUPQ
How do I array a part long a helix?
I am trying to draw a set of ferrite beads on a coil of coax cable
I generated the coil using 3D Sketch-> helix, sketched a circular profile  to sweep along the helix for the Coax cable.
so far so good.
I set a working point on the outer perimeter of the profile and arrayed the working points.
I opened an assembly, inserted the coil, constrained the bead (using insert) to the end of the coil.
This is the part that didn't work.
In the assembly tab I used pattern component -> feature pattern select.  Inventor would not let me select the points for for the feature.
Any thought on how to proceed?
Inventor pro 2022
Cheers,
Dave
Replies (13)
Message 2 of 14
admaiora
Can you attach the assy and the part?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 14
dwendlandKWUPQ
Thank you for the reply.
please find attached three files the coil part the washer part (test Item) and the asssembly
Cheers,
Dave
Message 4 of 14
admaiora
Hi Dave,
Do you mean the array like this?
Admaiora
Message 5 of 14
blandb
In the coil, if you change your work point pattern to:
Then you should be able to use the "Feature Pattern Function" in the assy:
Choosing the washer as the component, then in the model browser change from Assembly mode to Modeling mode and choose the rectangular patter you used for the work points:
Autodesk Certified Professional
Message 6 of 14
admaiora
Admaiora
Message 7 of 14
dwendlandKWUPQ
Thank you,
Yes that is what I was trying to do.
on the  same note is there a way to offset the first part from the end of the coil? or offset the first work point from the end of the coil?
Message 8 of 14
admaiora
Only the first or all the istances?
Admaiora
Message 9 of 14
admaiora
You can constrain the fisrt where you want than it will follow the array accordingly.
Admaiora
Message 10 of 14
dwendlandKWUPQ
the idea is to start the first part away form the beginning of the coil  so All instances shift  along the coil by some offset
Does that make sense?
Message 11 of 14
admaiora
Yes!
Admaiora
Message 12 of 14
dwendlandKWUPQ
I saw the  reply about constraining the first part. is there an easy way other than manually defining a an offset plane in the coil part and then referencing the working points that plane?
Message 13 of 14
blandb
See if the attached video helps?
Message 14 of 14
dwendlandKWUPQ
That video was helpful!
Thanks you for all the replies!
