Is there any way to directly measure the area of a loop on a part? Inventor (2019) just reports the total length. I'd like to avoid doing a temporary extrusion just to get a face to measure area. It's a planar closed loop, so I think should be easy for Inventor. I feel like this was possible before the "one size fits all" measure tool.
Solved by pcrawley. Go to Solution.
And which version of Inventor are you using? In Inventor 2023, while editing the sketch, right click in the and choose Region Properties, then select the closed loop of interest. You'll get area and much more.
Region Properties is also in the Inspect ribbon > Measure panel.
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
As mentioned: Region properties. (easiest)
Another option might be a Boundry patch (wich can be adaptive and doesnt need to be temporary)
@jjstr8 wrote:
I would still have to temporarily create a sketch.
I don't understand this statement.
Can you Attach a *.ipt that illustrates the issue?
@jjstr8 wrote:
Is there any way to directly measure the area of a loop on a part? ...just to get a face to measure area.
Maybe I misunderstood the question.
Is it about area of Loop or area of Face?
A *.ipt file might have helped illustrate the issue.
Hi! On 2023, the Measure command can measure distance, angle, body face area, and loop length. Right-click on the measure target -> Select Other -> select the exact geometry. Please share the example part here to facilitate the discussion.
Many thanks!
I thought my example description was straightforward, but here's a part file. I created a boundary patch as @Lucas.dolinarVFXZU suggested to show the loop that I want to measure the area.
Hi! Many thanks for sharing the file! As JD indicated earlier, you can measure the area of the surface. Is this what you were looking for?
I could be wrong, but is question: How to measure the area of a void?
In the sample model there is a boundary patch, and that is easy to measure - as is a temporary extrusion and all the other suggestions. If the area to measure is open space, there is no way to measure its open area.
You can measure the loop easily enough - but you don't get the area unless there is something there to measure.
@jjstr8 - Would you accept "No - you can't measure a void" as an answer? 😋
