It doesn't matter what units they use, the actual expression used by atan must be unitless, since they cancel out who cares. Inventor would assume degrees because the output of the function is degrees. If you want to change it to "mm" or "in" or "lengths of string", go ahead but I wouldn't waste time on it since it will not affect your result.
Regards
Stew
Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
Stew, AICP
Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
Windows 7 x64 Core i7 32GB Ram FX2000
