Application Options
Application Options
spl1970
Application Options
spl1970
I'd like to get an overview of the correct or preferred method for saving and retrieving the Application Options changes if possible.
If I make a change to the Application Options where should I export the file to? Where does Inventor read it from?
Simon
Frederick_Law
You can export it to anywhere.
You select where it is when you import it back.
mdavis22569
What are you wanting to do with it ..... ?
Share it and have other uses the same settings?
Have a back up of it?
Mike Davis
Mark.Lancaster
@spl1970
Your application options are user based information and stored in Windows registry under this section Computer\HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion<version #>\System\Preferences
As others pointed out, the export/import function of application options is only there to share (export/import) with others (or to have as backup of the information in-case you want to restore).
Mark Lancaster
johnsonshiue
Hi! Here is an article for your reference.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2019...
Many thanks!
Software Test Engineer
spl1970
Thanks @Mark.Lancaster,
I have a much better understanding now. What you're saying is that as soon as I hit 'apply' those changes are saved to Computer\HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion<version #>\System\Preferences and I don't need to do an export etc?
Simon
spl1970
Brilliant, thanks very much @johnsonshiue, very useful.
Simon
