Application Options File Open setting being Overridden
Jack_DuttonTM2JK
Jack_DuttonTM2JK
My team and I have recently run into an annoying bug in Inventor (2025.3). We're updating out company set Application Options; specifically the 'File Open Options' found in App. options > File > File Open... > Assembly
By default, it is set to Last Active. We want it to be set to [Primary]. We choose that setting and try to open a model not already in the primary model state. However it fails and continues to open models in that last active state. We double-check the setting, and it does stick; HOWEVER, if we close and re-open inventor the setting reverts back to Last Active.
We can, when opening a file, manually select the options and choose primary or any other model state. That will work and open the desired model state.
Anybody else experiencing this or know of a way to fix it?
johnsonshiue
Hi Jack,
The behavior does not sound right. I am able to reproduce it on 2025.3 and 2026.1. I am working with the project team to understand it better.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Jack_DuttonTM2JK
Thank you Johnson, appreciate the reply! Hope it's an easy fix.
Jack_DuttonTM2JK
Hello, Just wondering if the project team have been able to isolate this. If it does get fixed, will it get updated in the 2025 version or just the 2026?
johnsonshiue
Hi Jack,
Unfortunately, we have not  yet been able to identify the culprit. It is indeed reproducible. Please feel free to contact Autodesk Product Support and escalate it.
Many thanks!
Jack_DuttonTM2JK
Thank you Johnson, just submitted one. Case #24638488.
