Inventor Forum
Anyway to sweep this?
7 REPLIES 7
Message 1 of 8
451 Views, 7 Replies
Cooling sweep screenshot.pngHi,
I'm struggling to create a cooling pipe with branches.
I tried using the T&P tool in assembly but couldn't get it to work at all. So I tried using the sweep tool but it only sweeps the main path and not the branches.
Can someone please help.
7 REPLIES 7
Message 2 of 8
johnsonshiue
johnsonshiue
Hi! I think you will need multiple sweeps to do that. Inventor sweep only works for a path constituting a continuous loop. No branching is allowed.
Many thanks!
Software Test Engineer
Many thanks!
Message 3 of 8
JDMather
JDMather
What version of Inventor are you using?  2009? 2019?
Message 4 of 8
in reply to: JDMather
Message 5 of 8
JDMather
JDMather
See Attached file.
 Depending on how you are going to manufacture this - you might want to add some Fillets to the cross runs.
(Before or after the Shell, depending on manufacturing process.)
See Attached file.
Message 6 of 8
Thank you so much!
If I want to create additional pipes going into the page, would you recommend just adding additional sweeps to this or try and alter the sketch?
Thank you so much!
Message 7 of 8
JDMather
JDMather
@Anonymous wrote:
If I want to create additional pipes ...
Do the best you can using whatever techniques you need and then Attach your attempt here and I (or someone else) will demonstrate the most efficient technique.
Message 8 of 8
SBix26
SBix26
Another solution using Frame Generator:
Sam B
Inventor Pro 2019.3 | Windows 7 SP1
LinkedIn
Sam B
LinkedIn
