Inspect > Loop has gone missing in 2018.
Solved by SharkDesign. Go to Solution.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Yeah I read that too, but it doesn't work unless I'm doing it wrong.
Video shows 2017 loop and then 2018 measure. Doesn't work.
A similar thing can be achieved with 'region properties' but it's not the same.
Niels van der Veer
The Netherlands
You can't select multiple lines using ctrl or shift and neither can you drag a box around anything. This wouldn't work with a busy display.
Can't select loops on 3D geometry either.
Only way I can get it to work is to use the quickpick to get select a loop. Bit of step backwards really.
This is the new way to measure a loop, previous way was better as you could see instantly if it was a loop just by hovering which was useful for detecting open loops.
