any way to fix this error in mass on iam files ?
Darkforce_the_ilogic_guy
Advisor Advisor
any way to fix this error in mass on iam files ? when I make a part ipt file that have a weight of 1 kg(this weight is added to it ) to it , and then remove 1/2 of it on the in an iam files. Now it have chang the density form 1 g/cm3 to 2 g/cm3 and still have the same weight  the weight should be 1/2
Darkforce_the_ilogic_guy_0-1744714758672.pngDarkforce_the_ilogic_guy_1-1744714781641.png
CCarreiras
Hi!
It should run well, i tried and it work as supposed:
- I believe the part file is corrupted, since even when i change material in the part alone, the density (and therefore the mass), doesn't change.
- Also the assembly physical data says that there is a override in material, but i see Generic material in the part alone and also in the assembly context part.
I did all this in v2025.3
What version are you using? All updates installed?
I suggest to start a new part and try again.
Note:
Using your files, i had the same behaviour as you.
CCarreiras
