User Interface Customization - Storage location?
c_hoppen
c_hoppen
I have my own add-in that adds buttons to Inventor.
Now I can change the size of the icon, for example.
Inventor remembers this setting until the next session and the icon size originally defined in the add-in is overridden after the add-in is loaded.
Does anyone know where these settings are saved?
I assume in the registry under ‘Computer\HKEY_CURRENT_USER\Software\Autodesk\Inventor’ but I haven't found anything there.
The ‘Reset Ribbon’ command only seems to work for ‘built-in’ buttons.
Christoph
johnsonshiue
Hi! I believe these settings are saved to %AppData%\Autodesk\Inventor 202x\InventorCustomization.xml.
Many thanks!
Software Test Engineer
c_hoppen
Thanks, I have found a matching entry at the end of the xml file.
