Inventor Forum
Anti slip Appearance
4 REPLIES 4
lkirit2000
1210 Views, 4 Replies
Hi
Please see the attached image rubber anti slip strip.
Is it possible to show this strip line on a surface rather sketching the profile ?
Labels (1)
4 REPLIES 4
SBix26
in reply to: lkirit2000
Did you look through the available texture files?  Create a new appearance and try Pattern_7.bmp (in Public Documents\Autodesk\Inventor 20xx\Textures\Surfaces\).  There are three different corresponding bump map files, too, to help make it look more realistic.
Sam B
Inventor Pro 2021.0.1 | Windows 10 Home 1903
LinkedIn
lkirit2000
in reply to: SBix26
Hi
Thanks for your response.
I have applied. Not visible clearly. I need to adjust the scale.  How to do this ?
Please see the attached image,
mcgyvr
Just right click on each image in the appearance editor and select "edit image".. You can access the scale there.
lkirit2000
Hi
I tried editing, and hard to see.
Please see the attached image.
