Hi
Please see the attached image rubber anti slip strip.
Is it possible to show this strip line on a surface rather sketching the profile ?
Solved by mcgyvr. Go to Solution.
Solved by SBix26. Go to Solution.
Did you look through the available texture files? Create a new appearance and try Pattern_7.bmp (in Public Documents\Autodesk\Inventor 20xx\Textures\Surfaces\). There are three different corresponding bump map files, too, to help make it look more realistic.
Sam B
Inventor Pro 2021.0.1 | Windows 10 Home 1903
LinkedIn
Hi
Thanks for your response.
I have applied. Not visible clearly. I need to adjust the scale. How to do this ?
Please see the attached image,
Just right click on each image in the appearance editor and select "edit image".. You can access the scale there.
Hi
I tried editing, and hard to see.
Please see the attached image.
