ANSYS in Inventor
ANSYS in Inventor
不适用
20,200 次查看
21 条回复
1 条消息(共 22 条)
ANSYS in Inventor
不适用
Hi
I am trying to add the ANSYS 17.2 student version add-in to the INVENTOR 2017. However when I click on the add-ins icon in Inventor I see a list but cannot find Ansys 17.2 (workbench). Any suggestions would be great.
Edited by
Discussion_Admin
已接受的解答 (1)
20,201 次查看
21 条回复
回复 (21)
2 条消息(共 22 条)
Binga
Hello.
The add-in is installed when you install the ANSYS.
I searched for the add in separately and I didn't find it.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
3 条消息(共 22 条)
不适用
Hi, thanks for your reply, so are you suggesting to re-install ANSYS because I have already Installed it and I have also installed Inventor 2017 already but I am unable to find the add-in of ANSYS in inventor.
0 个赞
4 条消息(共 22 条)
Binga
Try modifying the installation, or using the CAD Configuration Manager of your software.
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
0 个赞
5 条消息(共 22 条)
不适用
ok will try that and let you know thanks
0 个赞
6 条消息(共 22 条)
不适用
Hi , I tried the CAD configuration from ANSYS but I get the following error message...
Prerequisites ..... Configure Success
AI Workbench Reader ..... Not Configured
Wny idea what it is?
0 个赞
7 条消息(共 22 条)
不适用
Any idea what it is?
0 个赞
8 条消息(共 22 条)
Binga
Hello @Anonymous.
I am not sure about that.
Try to contact the ANSYS forum!
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
0 个赞
9 条消息(共 22 条)
不适用
Yes, heloo i have the same problem, please would be helpful some information, to re update addins list
0 个赞
10 条消息(共 22 条)
不适用
已接受的解答
@Anonymous
You have to copy the cad file from your downloaded folder in you ANSYS and place it on the installed path like c or whereever you have installed your ANSYS . Then you have to run cad configuration of your ANSYS and click on inventor and do the configuration process there...... once done ropen inventor and you should get a pop up aski to disable or add the ANSYS plug ins and then uncheck the disable addins and your good to go... that is the only option that worked for me....
11 条消息(共 22 条)
不适用
what CAD file i have to copy? i have been looking around, and i think i have to configurate the CAD in ANSYS configuration CAD manager, but this give me an error, may be because i dont have the licence to do this, or somthing like that, so, i will ask th teacher, but its look like impossible.Thanks anyway
0 个赞
12 条消息(共 22 条)
不适用
open and run the [ANSYS} cad configuration manager and try to configure selected CAD interfaces as your previous unsuccessful attempts.
when this fails and gives the error   Prerequisites ..... Configure Success
                                                      AI Workbench PlugIn ..... Not Configured
go into the CADConfigurationMgr.log in   /ANSYS Inc
note the invalid Inventor DLL path   the configuration manager is looking for the file that is not there.
find the file in the downloaded package it should be in the folder [cads]
copy the relevant files to match the path that the configuration manager is looking for.
Re run the [ANSYS} cad configuration manager.
open inventor and accept the plug in.
13 条消息(共 22 条)
不适用
Thank you very much!!! this was the propper way!!! thank you so much!!!
0 个赞
14 条消息(共 22 条)
不适用
I don't understand where this  "downloaded package" is.  I have no file named "cads" either.
but in this directory, I find a few .dll files but I don't know if this is the one as it doesn't say inventor anywhere in the file name
C:\Program Files\ANSYS Inc\v172\commonfiles\CAD\Acis\winx64
 Here is a screenshot of whats in that folder. Please tell me what needs to be copied.
OK I did a little more searching and I found the place
<<Inventor PlugIn>>
Invalid Inventor Dll File Path in createAnsRegistryXML2 C:\Program Files\ANSYS Inc\v172\aisol\CADIntegration\Inventor\winx64\DSPlugInAICOM.dll
Detected Inventor Registry for version 2015
But the thing is there's no Inventor file there within the CADIntegration folder.
Thank You for your answers
0 个赞
15 条消息(共 22 条)
antoniober1967
The files you look for is in the downloaded instalation package of ANSYS: ("C:\Users\ANTONIO\Downloads\ANSYSACADEMICSTUDENT_172_WINX64\cads\ai" in my case);
In this directory there is a file:"WINX64.7z"; copy and extract it and you can see a Inventor folder; move this folder to the directory that causes installing error and run again CAD configuraction manager and you'll see that all is oK.
Aprender y compartir es la base de mi vida.
16 条消息(共 22 条)
不适用
Thanks man, it works just fine now.
0 个赞
17 条消息(共 22 条)
不适用
Hi, I understand the problem your facing.
Short Answer: You can't fix the issue anymore
Long Answer: Around February 2017, I was able to use Ansys 17.2 plug-in in Inventor 2017 by using the Ansys CAD Configuration Manager. But later the same year around October 2017, I tried the same thing with Inventor 2018 and Ansys 18.2. It didn't work. There wasn't even a CAD configuration manager in Ansys 18.2.
I followed this thread: https://studentcommunity.ansys.com/thread/cad-configuration-manager-not-installed/
In this thread, it was revealed that the CAD integration Option has been withdrawn for the student version of the software, so you'll no longer be able to use the plug-in feature. The option is available only in Commercial License Ones, the kind used by Companies.
The only suggestion I found was to create a CAD Model->export in .iges format -> import to SpaceClaim and then make all edits in SpaceClaim.
If you or anyone else reading this thread comes across a way to get the cad integration please post it here.
0 个赞
18 条消息(共 22 条)
不适用
thanx a lot sir for ur reply
0 个赞
19 条消息(共 22 条)
不适用
sir actually cad interface also not working in crack version ..........i faced problem in edit model ( when edit SW design)
0 个赞
20 条消息(共 22 条)
JDMather
Can you use super glue or duct tape to "repair" the crack?
0 个赞
