Autodesk Inventor
Autodesk Inventor
Autodesk Inventor
I'm new to inventor at this time. I made myself a drawing for my assembly and I'm struggling with the title blocks (ISO). The problem is that when I edit the ISO for each sheets they are all the same, with the same text. My goal is to get different texts in all of them so I can describe each sheets scale and so on. How do I solve the problem? Thanks
Accepted solutions (3)
CCarreiras
Then you have to place the iPropertie with text tool as automatic input in the titleblock.
Note: the titleblock is the same in all sheets, but if your model's view as different scales in each sheet, the propertie will catch the proper value.
Maybe a little complicated for you to understand, go to help and study better the process.
CCarreiras
mdavis22569
Hi and welcome to the forum
It would be helpful if you can share a bit of what you'd like. What'll you probably need is a custom IDW title block, that you can populate on each page.
Here is a good starting point/read from the AKN
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
and a google search
https://www.google.com/search?sourceid=chrome-psyapi2&ion=1&espv=2&ie=UTF-8&q=making%20a%20custom%20...
Video's search
https://www.google.com/search?q=making+a+custom+inventor+title+block&espv=2&source=lnms&tbm=vid&sa=X...
Mike
Mike Davis
Mark.Lancaster
@Anonymous
Welcome to the community..
Also when posting always indicate the version of Inventor you're using.  For example in Inventor 2016, a new feature was adding to allow the user to specify the "scale" of the model/base view automatically in the drawing title block.   Another thought for your question..  Look into Prompted Entries in your titleblock.
Mark Lancaster
