Another Learning Path issue: Bolted Connection.
justinthursday
justinthursday
I'm on this lesson now and having an issue with a bolted connection. Starting this video at 1:40:
https://www.autodesk.com/certification/learn/course/inventor-3d-modeling-mechanical-design-professio...
I've attached my own file with my current progress.
When I go to add the Bolted Connection as instructed, I get a red colored guide instead of green at the bottom plate where my blind start plane is and the holes become modified(shown in red) when they shouldn't:
Here's how the video lesson shows it should be at this point:
Moving on to the next lessons you can see I'm having the same issue which the next bolted connection. The Design Doctor shows there's something wrong with the holes and I'm not sure how to go about fixing it:
Most of the parts move as they should when manually dragged but I suspect this issue is interfering with the camshaft and top part from interacting properly. I've already created a contact set and used Activate Contact Solver. Things kind of move but they bind up.
I apologize if this isn't well explained. I'm new to Inventor and this issue is a bit above my head.
Thanks.
-Justin
johnsonshiue
Hi! If possible, please share the iam and ipt files in zip. The iam file by itself is not enough to represent the model.
Many thanks!
Software Test Engineer
