Animation Timeline Does Not Allow Edits. UI Needs Work.
ThePieMonster
ThePieMonster
I am trying to edit a existing animation in Inventor Studio 2023 and the UI definitely needs some work. It is completely counterintuitive to not be able to view the timeline and select the animation you wish to modify. In addition, selecting the constraint that was used initially does not allow the user to make any modifications to the animation.
JonathanKruger
That sounds like a good Inventor idea station post.
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
JDMather
@ThePieMonster
Attach your assembly here.
If data is proprietary then make up a dummy assembly that exhibits the same behavior and attach here.
s.bayat
What you are trying to do, adding two seperate events in the samen animation, which the first exist already. You should add a new anymation, like a second representation view and then you can put a new actual animation. Now it is like you want to animate two events at the same time.
