My animation of ic engine seems to work in 3d modelling environment , but it does not work in rendering environment.
To animate the ic engine i placed a angular constraint ( undirected) and used the drive command in constraint to animate it.
the above video the assembly file is in modelling environment.
The above one is in the rendering environment .
The engine doesnt make a full revolution.
Solved by johnsonshiue. Go to Solution.
Solved by blandb. Go to Solution.
Can you share your time line settings for the animation of the angle? Or can you pack and go your assembly for others to review?
Hi! I suspect there is some sort of conflicting constraints or a component flips 180 degree in certain condition. Please share the files here. The forum experts can help take a further look.
Many thanks!
these are the files, i will attach remaining files in next reply
i have placed a angular constraint between the XZ plane of crankshaft and XZ plane of origin of iam file. Then i used the drive command in constraint to animate , but it didnt work well
The above picture shows the timeline.
An IAM file is just a file that links all parts to it, it will not automatically sent the associated files, you must also place in the files.
I just drove the angle constraint from 0 to 10 seconds and 0 degrees to 360*4...
Please see attached simple video
I just changed the angle constraint to either of the other types(directed and explicit) and it works fine.
Hi! I think this has something to do with the angular constraint. To persist the rotational direction, it is better to use the Explicit Refence Vector option. Edit the angular constraint -> click on the 3rd button -> select the shaft as the reference vector. I believe the animation will work better.
Many thanks!
