animation issues #2
animation issues #2
animation issues #2
Hi!
I am trying to animate hydrocylinder.
I need to pull out white part for 10 mm.
In https://forums.autodesk.com/t5/inventor-forum/animation-issues/m-p/7262458#M653030   @JDMather  has shown me solution to my problem.
It works fine, but in the tutorial it works in other way.
@JDMather   or some one else please show me the way
here is the tutorial  I use
https://www.youtube.com/watch?v=bMB6Z2r12-Y
at 2:00 the author sets constraints animation
The assembly is attached
Many thanks!
JDMather
Are your Insert constraints at the correct locations?
@JDMather,
thank you for reply!
How do I check that?
Should I watch the tutorial or there is another way?
Thanks!
JDMather
Check your zero position in the video.
Is zero position fully extended, or is zero position fully retracted?
I didn't watch the video, but used logic - that is, "what makes sense to me in the real world" (see attached assembly).
